im having problems with my Neutral Safety Switch (NSS) and wanted to know if i can bypass it i have the part on order the only problem is i use my truck as a daily driver and it isnt starting up cause the NSS if there is a way to by pass it for a few days til the new NSS comes in so i can swap it out with the old one.
yeah, I recall dad and my uncle trying to pull an engine out of a caddy at a yard and that same thing happened; almost ran both of them over. The owner of the truck shrugged, ealked away and said as he turned to leave the yard; "You fellows are welcome to any parts or all of it if want, I almost killed you..heading over for some drinks."
Neutral Safety Switch (also referred to as Back-Up Switch) Installation & pics in an 89; "...It probably took me a total of 5 minutes to change this part. As you can see in the pic it has two bolts holding it on and one nut holding on the downshift lever. the hardest part is the downshift lever has to be immobilized while you loosen the nut. You can do this with a screwdriver like me or the book says to use a guage rod or something. You can get to it on the drivers side of the tranny. Here is a pic of it installed..."
Source: by Mad Dog Tannen at http://fullsizebronco.com/forum/showthread.php?t=173118&page=2
Neutral Safety Switch Adjustment
Source: by Tim O (RED WAGON, redwagon) at http://fullsizebronco.com/forum/showthread.php?t=149087
Neutral Safety Switch Wiring Color Codes in an 89
Source: by Uncle_Monkey at http://fullsizebronco.com/forum/showthread.php?t=173356
1974 Nova, LT1 built motor. My first daughter decides to come early. I jump in the Nova, girlfriend opens passanger door. As she is getting in I crank the motor over. Car is still in reverse, no safety switch. Car jumps backwards, takes out a garage door and sends my now ex flying when the door hit her.
