1 - 4 of 4 Posts
Tailshaft housings are different between 2wd and 4x4, dunno if the shafts inside will swap, but I wouldn't keep my hopes up.
Tail shafts can be swapped to make the tranny work on your Bronco. But, you will have to tear both trannys down to remove and replace the tail shaft. Is the tranny from the 78' F-250 coupled to a 351/400M or 426? If not, then the tranny won't even fit the engine.
1 - 4 of 4 Posts
