1 - 9 of 9 Posts
Does anyone know the length of a c-6 and a 205. I have searched and been unsuccessful. Thanks for the help
I just measured one..came up with 41" from the engine-mating face of the tranny bell to the u-joint center (bolt face) of the rear yoke.
redwagon said:
from tip to end? also which c-6? for small block or big block?
Tip?..end?. What was not clear about the description I used above? It's the lenght from the block face to the rear u-joint yoke...which is as long as it gets. The one I measured is sitting in a 78 F-250 frame...'big block' C6 bell.
Administrator
2012 Jeep JKU
sorry posted same time you did...was asking the on the first question...should have qouted I guess.:whiteflag
Exactly the info that I needed thanks
A couple more measurements 'from the yard':
Small-block and big-block C6 are both same length - 20" approx.
Assembled C6 and BW1356 T-case are 42" LOA..1" longer than the C6/NP205
79 and ealrier the 4x4 C6 could be found in two different over all lengths and in 80 the t-cases switched so another over all length came into the picture.
1 - 9 of 9 Posts
