I have a 4 wheel drive c6 that is broke in my 83 bronco. I was given a two wheel drive C6. Does anyone know if you can just swap the the rear sections and if you can how do you get the rear shaft out.
RBV Abuser, F/S user
To swap everything to make a 4wd tranny, you are looking at basically a complete overhaul to get the parts out/back in.
:stupid
The output shaft has to be swapped out. And the output shaft is the last part out when disassembling, and first part in on a rebuild. So this means a complete tear down to make a 2wd tranny into a 4wd tranny.
