1 - 8 of 8 Posts
on my 81 bronco with c6 tranny i was driving on the highway going 70mph and the tranny spun and now i could drive it on second gear and 55mph. I just got it rebult 3 yrs ago. will i have to rebuid it again.
If i do is there an overdrive tranny for a bigblock.
Wrenching for a Livin'
your vaccum modulator is probably bad, or the vaccum line goin to it has come off. I forgot to hook mine back up when i put on my new carb and it did the same thing.
So is it on the tranny where i should look.
Oh and i also just added a stopleak before it did it. Could that have somthing to do with it.
you added stop leak to the tranny? I'm assuming it was leaking . . . I don't if this would explain what is going on with your 3rd gear but make sure you don't have too much fluid in your tranny . . . too little and too much don't do well with trannies . . .
I think it has too much fluid. would that give me this problem.
Should i drain the tranny and change the filter and get the right fluid level.
Roller rockers are gay
it's not supposed to be leaking, change the modulator. it's easy, search for it.
IIRC its on the pass side close to the bottom. Should be the only vacm line runnin to the trans
1 - 8 of 8 Posts
