I have a fresh c6 bolted up to my 351w. When I first started it I was able to drive about 1/16 of a mile. Then forward no longer worked. I can drive in reverse but nothing going forward. Fluid levels are fine. TC is engaged in the pump. Which issues/problems could cause the tranny not to engage the forward gears? The neutral safety switch wires are not attached, vacuum lines are a bit suspect, but could this cause the tranny not to engage forward gears at all?
The rebuild is legit. I'm wondering which issues could cause the tranny to engage reverse but not forward. Park and reverse are fine.
press ALT+F4
I'm not insinuating it isn't legit. I asked "by whom" so if the answer is "me" we could discuss some tech, being this is a tech forum. Best of luck to you with this.
