rolled the bronco :cry was wondering how hard a cab change is if anyone has done one or any tips, suggestions, pointers. my front and rear fiberglass is still ok. thanks
get out the ol sawzall and make a convertable. have a shop make you a custom top. i bet it would be cheaper and a hell of alot easier than swapping the body.
Depends on how much you have to swap. If all you getting is a bare cab, that's a lot of time to swap everything over. not hard physically but time consuming.
The physically hardest part would be having a few friends over to lift the old cab off and put the "new" cab in place.
I've done it but expect a lot of time involved and plan on finding more stuff you want to fix as you go. Like clean the frame up while it's easy to get to.
I did one about 9 months ago. The hardest part was getting the chassis mount bolts undone. The rest was easy stuff, just get some masking tape and label all your connectors on both sides so you know what goes where. Also, have a pad of paper or a good memory to remember what bolts go where.it really was quite easy, but as mentioned above it's time-consuming and you need a tractor or 4-5 friends to help you lift the bugger. My new wife and I are gonna do one again in a few months, and we're not intimidated at all. Good Luck!
This is an older thread, you may not receive a response, and could
be reviving an old thread. Please consider creating a new thread.
Bronco Forum - Full Size Ford Bronco Forum
A forum community dedicated to all Ford Bronco owners and enthusiasts including the new 2021 Ford Bronco. Join the discussion about specs, photos, news, pricing, modifications, maintenance, and more!
