1 - 17 of 17 Posts
I'm looking for some help for my next addition to my Dana 44 article. Only the front drive axle.
First and foremost I need the BOM! before I can use the photos, Then...
I'd like pictures from the following:
So If you've one or more of the following, please send me a PM...
F100 & F150's
1961 – 1965 low pinion:
1965.5 RS (Not even sure this axle ever existed!)
1966-1971 Open Kingpins & 260’s U-joints
1971.5-1972 Ball Joints & 260’s U-joints
1973-1975 Drums
1976-1977
1978 – 1979
1980 - 1996 IFS
F150 SuperCab
1977-1979
U100 aka Early Bronco
1966 - 1971 Dana 30 King Pins
1971 - 1975 Drum Dana 44
1976 - 1977 Disks
FS Bronco
1978 - 1979
F250 3/4 ton
1967 - 1968
1969 – 1975 Small Kingpin
1969 – 1975 Large Kingpin, Drums.
1976-1977.5 - Have this one
1977.5-1979 New Dana 44 RS
1974-1975 Dana 60 Low Pinion closed Kingpin Crew-Cab
1976-1977 Dana 60 Low Pinion, Open Kingpin Crew-Cab
F350 1 ton
1977.5-1977 F250 / F350
1986-1991 DRW
1988- 1991 - Already have this one
1992-1998 Might ahve this one. Ball joint axle.
I NEED the following pics for each one listed above, Large is good. 3+ Mega pexils is best
Example of what I need from each axle.
Front low to show axle and wheels. . . . Tube with Tape Measure.
Front pumpkin
Missing
Front inner and outer knuckle Driver side . . . Front inner and outer knuckle Passenger side
Top showing knuckle BJ's or KP's.
Missing
Back pumpkin . . . Back inner and outer knuckle.
Back pumpkin and Knuckles. . . . Side Hub with a Large Tapemeasure showing hub size.
negative creep
87 KP d60 DRW
DRW vs SRW hubs
let me know if any of these work, i probably have bigger versions. i can get the BOM this weekend.
Charlie don't surf..
'92 Ford Bronco XLT
Solid front from a '78 Bronco. Tons of pics on my Supermotors Site.
You missed that some D60's were under 250's in 78-79. I know this cause i have one. It came out of a sno-fighter package. i can get the BOM for you if you want. here is a pic of my front axle which is in the back.
Mr.N said:
Thanks guys :thumbup , PM sent.
No 78-79 Bronco guys with a digi camera?
I have a '78 F-150 Supercab axle. Seeing as how your site greatly helped me during my SAS, I'll
gladly get you some pics; hopefully this weekend, if it stops raining.
Former owner of Shadofax
Well, I don't have a 78-79 cept the front D44 axle, but I figured you'd rather see nice stock stuff. My stuff you'd have a lot of 'splainin' to do with steering, chevy outers, etc. isn't a pic of factory junkyard stuff to look for. Unless your next chapter is going to show pics of mix/match of outer options, in which case you might like some pics of mine. The whole thing is purdy though, unlike some of your older pics from midwest axles.....the rust makes some of those axles practically unrecognizable.
Discussion Starter · #12 ·
Yep, I need to finish the stock stuff first.
I started a rough draft as to WMS-WMS and how it changes with different parts. Man does it get long, not sure what to do with that yet.
I'll take you up on that next winter!
Most of my old pics were done with a point and shoot 1.2 megapixel camers. I did get a 2.1 for a few shots, but that was a $1200+ camera in it's day.
Sounds like you've been list'n to C.W. McCall
Discussion Starter · #15 ·
BambiBasher said:
well your 1 ton section only has up to 77.5
I have it fixed on my draft page.
F250 vs F350 Dana 60 in 77.5-79 ... It's like the Full size Bronco and 1/2 ton truck of 78-79... Do I split them up or run them together?
They both use the same axle. (Ok the F150 has an axle code that doesn't show up under the Bronco, but it's close enough it doesn't matter)
At first I was thinking not needed, run them together with explanation on what option the front F250 could be. Then I was thinking it might be useful for folks to understand that the F250 with D60 front will always be matched to a 60 year (I think, I don't know this for sure). But, during those years would an F350 always have gotten a 60? I'm thinking no. The only importance here is for those looking for a single donor vehicle.
yes...digi cameras are like 'puters...the tech moves so quickly, my 2mp canon is old now after 2 years, and I can be the new canon 4mp for the same price mine was.
Discussion Starter · #17 ·
Good points! Thus the split. However my rear axle info will be limited...
(only for the 1970's... up to 1980)
As a rule of thumb, your right! Most F250's have the 60 and F350 have the 70... I'll make it clear on my draft page. for a peek change the 2 to a 3 on the one page... nuff said.
The F250 Club Cab had a Dana 70...
Some 1980's 4x4 F350's had a Dana 61...
1 - 17 of 17 Posts
