1 - 13 of 13 Posts
i have a 79 bronco with a 460 and c-6. my tranny blew apart in april
and i bought a 75 lincoln with a 460 and a c-6. can i convert the 2wd c-6 to the 4wd tranny without to much trouble. i would like to keep the engine
and tranny mated if possible..
Administrator
2012 Jeep JKU
I believe all you need is the output shaft and tail housing from a 4wd c-6, but your gonna have to take the trans apart to put them in.
i have a 4x4 c-6 in the bronco i need to know if the 2wd can be converted with the 4x4 parts on my c-6 in the bronco
yes
ok it can be , then is it a easy swap with out taring the tranny all apart???
Read.
You have to rip the WHOLE trans apart to do the swap.
Discussion Starter · #10 ·
ok thank for the info guys .now that i have to do a tear down i need to order parts to build
a stronger and lower geared tranny so thanks again....
1 - 13 of 13 Posts
