my bronco o2 plug has 4 leads in it...and the o2 sensor that "was" in it was a 4 wire bosche.
HOWEVER, I had extra o2 sensors laying around (sadly all bosche)...that were three wire, though they had the exact same pig tail that fit right into my bronco...
I tested voltage, and the one I used seems to be bad...stuck around .515 volts or so, whether I introduce a vacuum leak or not....
I go to parts stores, and they have both three and 4 wire for the same car.
Research tells me the 4th wire is only how it grounds...whether it grounds through the harness...a 4 wire, or whether it grounds through the o2 chassis into the exhaust (3 wire)....
So anyone have any more input on this?? I'm going to buy a new o2 sensor, since I was told to stay away from bosche, and the ones I have don't seem to be operating very well...I was looking at Denso...or ngk, any opinions there??
Just want to make sure the sensor I buy will work properly.
