I finally got some time to work on the bronco again.
I have removed the hood, radiator and entire front clip.
My question is can I remove the engine, transmission and transfer case all at one time?
I have a 2 ton engine hoist/crane on wheels that I plan to use to lift and slide the whole assembly out.
I am putting in a different engine and transmission but reusing my old transfer case. I would rather pull everything out at once if possible.
Is it easier to remove the bolts from the motor mounts where they attach to the frame or the engine?
This is my first time doing a big job like this, so any tips are welcome. I am a total newbe but just learning by doing. I would greatly appreciate any tips.
I will being updating on my build thread soon, thanks
