G
Thinking out loud here. I get KOEO and CO codes 67,85, & 84 then 11 for CO pass. 67 is MLP neutral drive switch or neutral pressure switch (pressure switch must be for an auto, I have a standard) I think the fact that the sensor is out is why I'm not getting KOER. 84 and 85 should not matter and I don't run those emission devices. Any thoughts? Am I right? I guess I need to replace that sensor if its wiring is ok. I also wired the clutch switch closed so I can start in granny. Would this cause it?
G
So I have a mustang computer and I need to ground or ref voltage pin 30 to get codes??????????????????????????????
G
Gracias Garcias or or grassy a$$
Thanks You
Domo autigato
Good timing I'm heating the engine now to work on it, it's cold out!
