Maybe one of you guys can help me. 89 Bronco XLT 302. When I pump gas I get the clicks. I think it's because not enough air is a able to escape as gas goes into the tank causing the pump to think my truck is full and it stops. Takes about 30 min to pump a full tank holding the handle pumping it ever so slow.
What's a way to fix this? Maybe a Y pipe where the gas hose goes into the tank. The orig. Gas hose into one side of the Y pipe and a new hose into the other Y pipe with a fuel filter at end to prevent gas from comming out of that hose.. Or maybe run that second hose up to the gas fill spot and drill a hole next to where the pump goes in and just cap second hose after fill up??
