1 - 11 of 11 Posts
So both my captains chairs, lower section, have rips/tears in only
the outer "solid" fabric sections. The centers look great, otherwise.
I got samples from SMS and they look great. The solid fabric is much cheaper
than the weave center, too.
Is it possible to have an upholstery place re-use the center section, and just fix
the outer edges?
Reactions: canuckistan97
Only thing wrong with pass seat.
Drivers. Weave really is in great shape.
Ah I see what you meant. Yes an upholstery place can save that middle fabric and just replace the vinyl on the sides very easily
Fabric is brittle and trying to tie back in will likely be problematic.
1979 Bronco Ranger XLT, 400m engine, C6 trans, D44 front with Dick Cepek manual locking hubs
not sure if we can answer this question.
Why don't you talk to an upholstery - showing what you got and what you want them to do?
Could be, Will let upholstery guy decide. I guess if he has to sew both sides of that center, how
much more work would it be to replace? How hard is it to re-create those depressed sections,
in center "weave" that run front to back?
Will do, just like to ask up front in case someone has done it.
(plus I haven't posted anything in like 12 years it seems :))
Reactions: simrokkzz
78 BRONCO RANGER XLT -351M-C6-NP203 TO 205 SWAP -9IN 3.50 REAR
The place I went to did with mine-changed outside vinyl with center fabs untouched-I guess you have to search around to find that person who can do it-good luck (y)-greatest money spent
164771
1 - 11 of 11 Posts
