Hi Bronco Tech.
I introduced myself the end of last week with the post Got me a Bronco witb a problem. I got some feedback that it might be the choke and so I took it into the local tunex and had it adjusted... let's just say that I'm getting my money back. I guess it does start better, but when it runs... well, read on.
I bought a 1984 FSB from a guy. This particular FSB got a new engine about 515 miles ago (I have the papers, it's pedigree!). The engine is a 351w with a Holley 4bbl carburetor. Well, when I got it, it had a very hard time starting and would flood out sometimes. I heard it might be the choke, and tunex told me that the choke was too tight. after adjustment, it does start better, but it's still got a problem:
First, it doesn't high idle very well. Tunex adjusted the high idle, and I guess it does kick in but once every 5th start or so. It's still not great.
Second, it seems to idle really low. In park, it idles about 600 rpms, and when put in gear, it drops to about 400 rpm or lower causing it to sometimes stall. Something tells me that is too low. Should I get it adjusted higher?
Finally, when driving, it runs ok, but if I come to a stop, it'll drop down to it's 400rpm idle. (here's the kicker), when I press the gas to go again, it revvs up to about 800rpm and then stalls out.... Almost every time whether cold or not! this is why I am getting my money back from Tunex.
This morning, I started it and let it idle in the driveway for about 10 minutes. This got it up to full operating temperature, so it should run just fine right? Nope! I got to the first stop sign and stalled out in the middle of the intersection because of the aforementioned problem. Now, I have heard that the Holley is a temperamental carburetor and the dude at tunex suggested getting an Edelbrock for the job.
My questions are these, Is there any indicator to any of you what the problem might be? I'm going to turn up the low idle tonight as a temp fix, but i'm sure that's not the real underlying problem. Is it too lean? Is it too rich? should call the company that installed the engine and have them fix the problem?
Any help would be greatly appreciated...
