I rebuilt the carb myself. The instructions that came with the kit are in my link. Here is the question: I went to start the truck last night, it fired fine and idled for about 30 secs then I stepped on the gas a little to drop the idle and it bogged and died. Then I fired it back up and everytime I hit the gas, as soon as I let off it dies. So then I knew it was still cold so I held on the gas to about 1200 rpm and once I let go it died. So I did it for about 2 minutes and then I put it in gear and it died. So I fired it and gas it some gas and droped it into gear, and held the brake while giving it a little gas. THen I released the gas and it idled fine.
Fast Idle screw set to 750 rpm ( while in gear)
Choke is set to factory position- should I adjust it to open more or make it close tighter?
Air screws are set to factory specs.
So what adjustments if any should I make?
It did rain yestarday and I wasn't able to check anything out because I was in a hurry and had to take the other car.
