.......sorry ......i had to go do something...i think mathew is right ,...are you replaceing it.. or rebuilding it,?...when shopping for a carb find out how good the one you want performs at different extreme angles, e-mailing a tech at the company usually gets this info.......this is why fuel injection has some advantages over carburetion, when 4 wheeling......
Surrounded by Assholes
If it is stock and has a rubberline attached to each bowl it is a 4180, and a real piece of crap. If it doesnt have these outlets, it is most likely a 4160.
Rest in Peace Friend...
Larston said:
Go to www.holley.com and look up your number in their tech support section.
If it is a 4180, it probably won't be on their list. The 4180 was only made for Ford and is obsolite. You can only get remanufactured ones. If you are going to replace it, you probably would be better off with something like the Truck Avenger.
