Hello, I have my cb radio's positive and negative power lines connected directly to the battery. The powerlines are run through the cab and around the engine as far away as possible from the ingnition cables. The case of the radio is grounded at the chassis, which seems to help alot to reduce SWR. when I'm driving I get alot of engine noise.
Its bothered me to the point where I put layers of aluminium foil over the power lines in the engine compartment. This worked a little but not enough. I have to turn the squelch on so high I cant even hear relatively strong singnals while driving.
Anybody know of any tips to get rid of engine interference? I have properly grounded the hood, radio, antenna, and engineblock. Other than this, I dont have any ideas as how to reduce this noise.
