1 - 14 of 14 Posts
Allright, I've looked around on different websites and searched a good deal, but I can't really find a definitive answer as to whether or not I should ground the black wire from my CB or connect it to the negative terminal of my battery. I've read to do both.
Sorry to ask the most elementary question. God knows I've read enough about SWR and coax cable length theory. Thanks.
Steve83 said:
Ground it, like anything else. As long as your battery cables & ground points are good, there's no reason to run ANY ground wire all the way to the battery. That'll only mask other problems.
Thanks. Off the garage:rockon
USAF C-17 Maintenance
As long as your neg battery cable is good, any ground you put to some good metal should be good as well.
Adrianspeeder
You can ground to the battery if you like, but you would get the best reception if you just ground th shortest length to a good ground on the frame etc. I cant say nothin, I am running a ground straight to the battery....
Wrenching for a Livin'
I wouldn't ground straight to the battery.
If your main ground cable ever goes bad, the whole truck would be grounded thru the CB
So, for instance, a metal bolt that that holds down the brake pedal is fine?
P.S.- Thanks for the help guys.
Yeah, the best ground is the shortest length to a good ground...good advice, Too bad I havent taken it yet
i helped a friend wire a cb in and he grounded it to the frame and we could hear interferrence, the higher the rpm's the louder and higher pitched the sound was. same thig happened to my sister when she did hers. a noise filter will take care of the noise but thats more money to spend whenall you have to do is spend a few more minuets to find a better ground.
Mine is powered off the back of the cigarette lighter and grounded the same way the lighter is too. It has given me no problems or noise.
The more Grounding pionts u have the better.. I drive truck for a living and i use to just ground to the chasy now i do 2 chasy grounds and strait to the bat if one failes then it has a back up..
Yup, I'm fullsize....
Check out the following article for routing power to a mobile radio:
http://www.k0bg.com/wiring.html
While the article is geared toward HF mobile radio, the priciples still apply.
Steve83 said:
:topic
B&B
That "h" in the top center of your sig pic should be "H". If that's a capital H in that font: OK. But it doesn't look right. :shrug Otherwise, there should be no space between the "l" & "h".
its all one word actually, teufelhunden, i dont know why its seperated like that. but yeah i was lookin at that after you said it and it does look kinda goofy, but it dont bother me.
1 - 14 of 14 Posts
