:scratchhe
I just installed my CB, it's a Cobra 29 WX NW ST C and 4' Wilson Silverload antenna with 18' coax cable, mounted on the tire carrier bracket.
My antenna ground is good (checked continuity) and the radio has the SWR adj feature so I went to a big open parking lot to get the antenna "tuned", I also made sure to not "coil" the coax.
The range of "good reception" only seems to be about 1-1/2 miles. Is that normaly what to expect?
I read about tweaking the radio for more wattage and was wondering if this improves both the range of reception and transmission, (or is it just one)
Also I get some engine/alternator whine.....(I connected + lead to cig lighter wire) and after hearing the engine noise I installed a good radio noise filter that both the pos & neg leads pass through, but only got a slight improvement.
I wonder if going directly to the battery is going to make a significant difference.:scratchhe
Any input is appreciated.
Jim
Wrenching for a Livin'
How many watts is that radio suppose to put? More wattage is gonna get your out farther definitly. Do you know somebody with a swr/watt meter? See how much wattage you got reflecting back into the radio, that will give you an idea of how well tuned the antenna is
tweaking it will increase the output wattage. I had my midland up around 18 watts.
As for reception, I could talk to basecamp from around 3 mountains over.
4 watts
Get me out further????? meaning both reception and transmition?
Well thats what I'm trying to decide in this thread, whether or not I can get much improvement by going to a CB shop and having a pro do it up.
Thanks,
Jim
Try it now!!
jimsl78 said:
:I wonder if going directly to the battery is going to make a significant difference.:scratchhe
Jim
I've installed a ham radio or twelve in my day.
Yes, makes a huge difference. Dooo ittttt...
-Will
Getting your radio peakd & tweekd is worth it...Theres differant things to do in the radio to get both more output & input...Also you can get a preamp & that will help with your receive...Or go the easy route & just get an amp...But ALWAYS check your SWRs every few months...They are constantly changing...
If you cant find a CB shop by you to do the work you can send it to Justin at the link below..Him & his shop are 1 of the very few people I trust to work on my radios...
http://www.communicationsexperts.com./
& for some great info try this link...Iv been there for about 5 years now & have learnd alot...
http://forum.worldwidedx.com/
