InkDawg said:
you would be suprised what a tape measure can do...for centering it in the wheel well I used a string with a weight on the end and and attached to the same spots on both sides (plum bob I think it is called)...
yep, plumb bob from exact point on the frame, either side, for side to side. Front to back you should begin by ensuring the upper coil mount is located in the same position for each side, and then secondly find a matching frame point not far from where the RA's will connect to the frame to make sure your RA mounts are aligned.
This alignment is also why I liked going with left/right rod ends at either end of the DOM trackbar...it will allow for further fine tuning by turning the DOM and lengthing/shortening the trackbar.
FYI though, even doing this very carefully, my body to frame measurement is a bit off, which when measuring makes it appear the setup is off by about 1/2" side to side. Reality though is that the axle is aligned to the frame.
