I want to get 30' - 20' of chain with hooks on ea. end for towing, pulling, anchoring the Bronco, etc. Along with a 2"x30 or 3"x30 recovery strap.
My question, is will 5/16 chain rated at 4700lbs be strong enough for whatever I might find myself or others stuck in or do I need to get 3/8 chain rated at 6600lbs.
I have a Hi-Lift jack and will be getting the winching kit for it, also.
Winch will follow later!
Consider what you're doing with it.
6600lbs is fine, as long as all you're doing is a direct pull with it. The moment you snatch with your 3 ton truck, that 3 tons worth of weight multipies. It's all about application, and using something in the wrong application can have hazardous results.
Forward Some Money
I dont think I would use chain. I would use the straps for weight and safety. Plus the nylon doesnt rust. I bought a wrecker and the included chains were like a pile of rusty dog crap. I use the straps for almost everything.
I agree, bigger is better for the most part! I was thinking the recovery strap for pulling out Jeeps:goodfinge And, if I felt like getting a good work out I would use the chain with the Hi-Lift to manual jack/winch out those Jeeps!
Also, going to get 75'-100' feet of 3/8 cable and snatch block to double the load!
Looks like 3/8's is the way to go!:beer
