1 - 3 of 3 Posts
ihow do i remove the caliper on the front disc brake on an 88 bronco???
i took out the screw that runs from the brake fluid line and there is 2 other screws i see..
one is on the caliper itself with a bleedable nipple on it and another one on the axle i think!!!
i knw this shouldnt be this hard and i need 2 hurry up n finish this its getting dark out here!!!
thanx a million!!
He may have this type of pin holding in hte caliper
http://shop.advanceautoparts.com/we...rake_5312906-P_351_R|GRPBRHWAMS_1250444043___
If so than he has to pinch the 2 metal pieces together on the pin and push it throught with a punch and hammer. Have to pinch and push at teh same time. You dont have to take off the brake line, now you will have to bleed the brake system since you took off the brake line from the caliper.
1 - 3 of 3 Posts
