1 - 9 of 9 Posts
Hi again. I've had my Bronco for about 5 months now and i really wanted to change the differential fluids on her. I'm not sure if they have ever been changed so i figure i'd rather be safe than sorry. Plus I'm going to be taking her off road so i wanted to make sure this was done right.
Ok, here we go: What fluids do i replace the front and rear differentail with (brand, grade, weights?) and are there any type off additives i need to put in? I know my mustang needed an additive for limited slip. Also what do i put in the transfer case and the tranny. She has a stock 4spd.
Thanks guys I really appreciate the help. I have a Chiltons manual but it really doesn't tell me what to use. Any more ideas what to change/lube before i hit the trails?
Rock on :rockon
I use the Lucas gear oil. No additives (except water and mud:doh0715: ). Expensive, but what the hell. I'd just spend the money on something else anyway.:beer
I run 85w140 in everything. I buy the stuff by the 5 gallon buckets.
Jopes is right, run 84w140, make sure that if you have a limited slip to put the additive in as well. I run a mix of Lucas and 85w140 in diffs and transfer case. I find the axles and transfer case run cooler with the Lucas. Through grease job never hurts either, make sur you grease up the drive shaft splines as well.
Checked my gear oil bottle and I used the 80/90 weight.
I believe the 78 Freewheeler Bronco package came with a limited slip rear. I think they had black bumpers too. Someone will chime in about the Freewheeler.
1 - 9 of 9 Posts
