221 - 240 of 275 Posts
1986 Bronco, 351w, Edelbrock aluminum top end, Holley 600, 4" BDS lift, 35" Maxxis Razr's, stuff..
Thanks @allcruisen
The color has worked out pretty well. The sections of my door panels where arms ride were pretty much polished smooth and the plastic so old that it really would not scuff up when prepping. Those areas have worn through to the red again. At some point i may opt for some new door panels.
More to come!
@dash_cam that locking hub mod on the tire carrier hinge is awesome. I love it. I would like to do that on mine somehow. Nice job and nice idea!
hey sorry buddy, i didn't see this before. i missed the alert.
thanks! i can't take too much credit, though. really, i can't take any at all. spktyr came up with that before i bought it. the main thing i changed on the bumper was the latch. otherwise we just implemented the concepts he already established. the tire mount is also from a factory mount.
The Tennessee Warden
96 XL, built 357W, E4OD, BW1356, 4.56 gears
Either way, I like it! So is it just a cut-off spindle shaft and cut-off rotor and all the bearings and internals from a normal hub I assume?
yea, pretty much.
here you can see the spindle. and it has wheel bearings in there and spindle nuts.
And.......these are obviously posted in the wrong thread!
@allcruisen I have not yet. I plan to go with a e-locker in front and a trac-loc in the rear with either 4.10’s or 4.56’s. That said, the truck is very drivable with the current 3.54 gears.
@biggum make sure you keep checking on those bolts that hold the front lift brackets to the cross member. If they start getting loose, they will make the front end feel sloppy and also it will "oval" the bolt holes in the bracket and it will never be able to be tight again. That is what happened to mine - one bracket with slight ovalling on a bolt hole. I am having a local buddy of mine throw a couple tack welds around the bracket to reinforce it.
FSB Pimpster & Recruiter
I'd say probably go with 4.56's I was talked out of the 4.56's to 4.10's and really regret not going with my gut feeling. Just do as much research as you can, it's not something you'll wanna redo if not happy.
With my 33's I like the 4.10's but with 35's, I know it could use the 4.56's
@MS88Bronc You beat me to it. :) I was gonna mention the same thing. I did re torque all bolts after 500 miles and now I check them at every oil change.
Allcruisen
I agree. I went with 4.56 and have 35's. I was considering 4.10's as a compromise as I have no OD, but went with 4.56 anyway. It gives a lot of low end grunt, that's for sure.
Yes, I’m leaning 4.56 and in the truetrac not trac lock
This
And that
Yes, I’m leaning 4.56 and in thdd Ed truetrac not trac lock
This
And that
Right now broncograveyard is doing 10% off all orders until the 29th, which I'm sure you noticed on their site. Doesn't seem like much, but it would probably cover the shipping on all that stuff if you pull the trigger on it.
i've got new 4.10s front and back plus new rebuild kits up in my attic. however, i am waiting to get my hands on a new front true-trac or equivalent worm gear limited slip. for the rear, i'll probably go with the same, but i already have the factory trac-lok so i go back and forth. may do gears and then later go back and do the rear limited slip.
however, i only have 31s and want 33s. if i was going 35 i'd do at least 4.56.
@allcruisen the mic does not have the channel indicator on it - just the buttons to change channels.
