1 - 20 of 32 Posts
Engineer
My dad had a $400 mitre saw that lasted about half an afternoon after he told me it could cut metal too... oops. I doubt they're worth the money at all
i got the cheaper one and so far alot of cutting and a couple years of use it is still ok. if you got slow and steady it is good if you want to go fast and alot of use the higher dollar one or better name brand might be better. i just tossed my $10 4 1/2" angle grinder after 6 years of use...the cooling blades broke of sometime last year and it was varaing speeds and alittle out of ballence but it worked great for $10. i replaced it with the $49 (on sale) 9" grinder and cut 450 spear points of the in laws fence.....mike
I have the 100 buck Harbor freight one. It cuts fine but it doesn't always make angles perfect. If your just going to make straight cuts you might be ok. I would definately recoment getting a higher end cutter. You will be happy in the long run
Ive got the cheaper one, ive had it about a year now and have used the poop out of it but it has been through three sets of brushes in the electric motor and seems to be on its last leg. I would have to say ive gotten my $$ out of it but i am going to upgrade for my next one. I would get the more expensive one it looks to be more sturdy
Past Bronco Owner
I bought the $50 one and it's a POS. I can do better with my HF 4 1/2" grinder with a cutoff wheel. I didn't listen when others said not to waste my time, maybe you will.
TTB Hater of course
Check the local pawn shops. They always have power tools and some are fairly nice. Just make sure you know what it's worth before you pay for it as some places mark stuff up so much it's not worth it.
forgot to say when i bought mine it came with upgrade liftime warrenty on certain parts. If you really want a kick ass saw get a millwalkee or dewalt cold saw i use one at work and cut though 2x2 1/4 wall in about 10 sec the saw cost about 600 and the blades 200 but damn if had the money
:stupid I bought one and returned it the next day. My 4 1/2" Milwaukee grinder was much quicker than that piece of junk.
TTB Hater of course
The dry cut Milwaukee is around $420
http://cgi.ebay.com/Milwaukee-14-Dr...ryZ43599QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and the blades are anywhere from $40 for a Freud on Ebay to $130 for the OEM Milwaukee Endurance blade. And yes, they're sweet, love mine.
Grinders, it's hard to make square cuts in anything but plate or sheet goods. Sawzalls have a place but the blades will quickly get spendy if you're cutting steel. An abrasive chop saw has it's place for sure, if you can't afford the dry cut. Band saws good, too.
I now have a DeWalt that is badass for tubing and stuff but I lasted a long time on the $100 one from Harbor Frieght, just need to replace the main shaft support bearing about once a year depending on use... about $3 at any bearing store
Rest in Peace Friend...
collinsperformance said:
i got the cheaper one and so far a lot of cutting and a couple years of use it is still OK. if you got slow and steady it is good if you want to go fast and a lot of use the higher dollar one or better name brand might be better. i just tossed my $10 4 1/2" angle grinder after 6 years of use...the cooling blades broke of sometime last year and it was varying speeds and a little out of balance but it worked great for $10. i replaced it with the $49 (on sale) 9" grinder and cut 450 spear points of the in laws fence.....mike
Ditto!!!! I did all my body work cutting and grinding with a cheap Firestorm cordless sawzall and a $10.00 angle grinder. That was the best $10.00 I ever spent. I figured if it would last a month I got my moneys worth out of it. 5 years later it is still there and still works fine. The only drawback is that it doesn't have a safety switch that cuts it off if you drop it, so keep something like this in mind when buying tools.
http://www.supermotors.net/getfile/108161/fullsize/bronco-0034.jpg
1 - 20 of 32 Posts
