1 - 3 of 3 Posts
Axle shaft sale time again..here's some updated pricing. These are FSB prices and can not be found elsewhere. You MUST identify yourself as an FSB member if you call. Make sure you ask for Eric.
Rear Axles
87-96 - $70.00
83-86 (8.8) - $70.00
80-86 (9.0) - $70.00
78-79 (9" brakes) - $70.00
Most axle bearing/seal kits are $10.99 with Timken bearings
Front Axles
80-96 (RH) - $165 New OEM
80-96 (LH) - $165 New OEM (Currently out of stock)
8.8 Master bearing kit - $72.40
D44 TTB Master bearing kit - $109.00
90-96 Bronco OE replacement rear drive shafts - $199.00
90-96 Bronco 1350 Series upgraded rear drive shafts - $260.00
87-89 Bronco w/ 5 spd & 4.9 / 5.0 - $165.00 26.5" C-C
Ford 9" 4.88 gears - $133.00
5-760X D44 U joints - $18.50 Spicer solid
Discussion Starter · #3 · (Edited)
Just outta curiosity, what about 78/79 D44 axle shafts?
I've got OE shafts for about 165ish. I don't have them in stock but I can put them in stock. Also got Cromo package for left and right for 575.34. Lifetime warranty.
This is for 30 spline inners. They are also showing a 16 spline inner..Not sure what that's about if anyone has any info on that.
1 - 3 of 3 Posts
