For those of you who dont like to search, here it is :goodfinge
Courtesy of www.broncofix.com
Coby's pics:
http://www.vintagebronco.com/coby/tierod/
Great pics from a guy using this setup on a Jeep Commanche pickup:
http://www.bc4x4.com/ryeguy/truck/detail_1.jpg shows tie rod height w/Scout knuckles
http://www.bc4x4.com/ryeguy/truck/detail_2.jpg
http://www.bc4x4.com/ryeguy/truck/detail_3.jpg
1) 1.250 OD x 0.812 ID DOM for the tie rod (tap directly into 0.812" ID)
-any tube with 0.812" ID or smaller will work and you can also go to a larger OD for additional strength. It is not receommended to go beyond 1.50" OD though.
2) 1.5" .120 DOM for sleeving (optional and only works with 1.25" OD tubes)
3) Tie rod tube should be about 38"for stock early Bronco knuckles (39.5" for 76-77 disk knuckles) and drag link should be about 25" for high misalignment ends and 27" if using the tie
rod ends for the drag link). If using the F150 box and the high misalignment ends, then the drag link tube length should be 18.75".
4) 7/8" x 18 UNS special left and right hand taps
Travers Tool Co, Inc
14-056-182 (plug style)7/8-18 right hand $20.47
McMaster-Carr
2595A424 7/8-18 right hand $49
2595A999 7/8-18 left hand $108
5) Reamer is 7 degrees (3.5 per side)
Afco Racing $120 p/n 80770
http://www.afcoracing.com/products/...yID=8ClassID=121SubclassID=565&ProductID=2631
Optional Reamer Sources:
Stock Car Products $80 p/n R8201
http://www.stockcarproducts.com/
Goodson $50 p/n TR-216-2
http://www.goodson.com/scripts/mshop/
Snap On $37 p/n R121
https://buy.snapon.com/
6) Rod ends
-pass side tie rod (with hole and regular misalignment) 85 Blazer
-driver side tie rod (regular misalignment) 85 Blazer
-pass side drag link end (high misalignment)
-pitman arm side drag link end (high misalignment)
Autozone:
ES2233L $25.99 pass side tie rod
ES2234R $23.99 driver side tie rod
ES2027L $18.99 high misalignment drag link end
ES2026R $20.99 high misalignment drag link end
Autozone Online Prices:
ES2234R $24.99 driver side tie rod
ES2027L $24.99 high misalignment drag link end
ES2026R $24.99 high misalignment drag link end
7) big end of the tie rod is .78" and the small end is around .67"
8) The tie rod ends should come with the jam nuts, but the drag links won't. I searched high and low for the source for the jam nuts and have only come up with the Chevy part numbers which are 14026805 (left hand) and 14026806 (right hand).
Coby's pics:
McMaster-Carr
6) Rod ends
Autozone:
