Has anybody ever done a clutch cable conversion with an NP435 Transmission? Are there any kits available?
I have an 85 Bronco with 351W and NP435. This was changed from an automatic to standard at some point, but not by me. The clutch components are the 78-79 ball pivot style with the motor side and frame side pivot brackets with the equalizer bar between them.
I am looking at other options because it is extremely difficult to get the pivot brackets. I can get the motor side one new for a whopping $85 but the frame side is not available. The pivots are so worn out on my bronco that the clutch barely works now, so I am looking at alternatives.
From doing some research I see you need to change the pivot point in your bellhousing so that a pull will push on the pressure plate instead of a push by your fork. So I guess a new bell housing, fork and some sort of cable kit would do it (maybe the pedals too).
Any help would be appreciated, even if you have a fix or source for the pivot style.
Thanks!
Thanks!
