1 - 11 of 11 Posts
I'm in need of a set of clutch pedals and a clutch rod for a np435 in a 79 bronco. I've got everything minus flywheel/clutch setup which I'm getting from McLeod.
How soon do you need it? I've got everything you need in my parts truck but it'll probably be a month before I strip the truck down due to the weather.
I'd like to have everything within 2 weeks or so, because I have a run coming up soon that I'd like to get the np435 swapped in for.
What exactly do you need?
I've got the following:
Clutch and brake pedal assembly with hanger bracket.
Rod from clutch pedal to the Z-bar
Z-bar
Z-bar pivots
Z-bar to clutch fork linkage.
I need the clutch and brake pedal assembly and bracket, rod from clutch pedal to z-bar, the pivots, and z-bar to clutch fork linkage.
Discussion Starter · #8 ·
Hey man if you can work me a good deal on everything I can wait till you can get em pulled. I have to wait for a while now anyway since I'm going to be designing a new front suspension for my truck.
Discussion Starter · #10 ·
That works. Let me know when you get everything pulled, and then I can send a payment.
I have what you are looking for if no one else on the board has helped you out
1 - 11 of 11 Posts
