I'm getting code 34 (CM, valve above closed limit), been getting it for a while. I decided that my EGR valve and not the solenoid or EVR (which is new) were to blame, so I pulled the EGR valve to clean it.
Anyways, I can pull air from the flange that bolts to the intake, but not from the lower portion that goes to the exhaust tube unless the valve is open with vacuum. The valve holds vacuum just fine so the diaphragm or EVR rubber gasket is just fine.
How is this even possible? and am I definitely stuck with getting a new EGR valve? ridiculous that these things are $100.. I just don't understand how I'm getting code 34, how I get no leakage to the exhaust tube, both the EVR and EVP test out fine.. this is driving me nuts
