Looks like I'm going to have to replace at least 1 of my coil towers on my '95 rustbucket and I was wondering if I can use a set of Early Bronco spring towers instead. I've got a set of spring and shock towers lying around my junk heap that would be quick, easy and most importantly, free to install. Has anyone done this? I would assume by looking at them that they are the same as the '78-'79 towers the guys are using on SAS conversions. Has anyone used them with TTB?
THX
Greg
I think they are shorter. I had a sas question about towers and others advised they were shorter than the 70-79 f150's.
why not put them next to the stock ttb towers and see exactly how different they are.. Will be a hell of a lot easier to physically see the difference..:shrug
It would work but there are a few things to consider
1. The tower may be shorter however I dont see where they would be much shorter than a TTB bucket.
2. The TTB coils and SA coils found under the earlier bronco's are wound differently at the bottom. So I would think you have to fab some way to mount them.
Thats all I got.
yeah yuou would need to devise a different mounting system depending on which coils you choose to use. I would actually be interested to see how it came out.
Thats all I got.
They're wound differently at the bottom, but the top is the same, right? If I use the towers from the SA the TTB coils should bolt right in. I have to cut the towers off what's left of an EB frame before I can test fit them.....I guess I'll have to wait until after snowmobiling season is over......:rockon
Greg
Greg
I am pretty sure that is correct. You might want to do a quick search on that though.
