1 - 9 of 9 Posts
I have 6in rough country coil springs up front and the front sags quite a bit. What brand do you recomend for stiffer 6in coils.
Why do you want stiffer springs on front.The TTB coils are already pretty stiff as they are. How long have you had the lift on there? Do you have a Winch bumper?
If you want to go stiffer coils then go Superlift or Rancho. IIRC those are really stiff coils.
Well the fact the front sat lower then rear when you lifted doesn't mean the coils are sagging. A lot and when I say a lot about 99% of the lift manufactors out there design their kits to where the fronts sit lower. It's the factory rake look.
What does your rear suspension consist of?
hey, the rear is made to sit higher, because when you put a big load inthe back it will make it sit flat with the front..
ExCom,
There are new bushings that you can get to correct your alignment. or how much you want for those 6"
1 - 9 of 9 Posts
