Ok guys so let me start off with the truck has sat in a shed for about 4 months or so, that is why it is so dirty and rusty. I do love this truck it start in a barn for 7 months while I was in Iraq only to fire right up the day I got home, didn't even need a jump! I have put about 60k miles on her and only thing to ever happen was a dead alt. and the belt tensioner broke... needless to say the belt tensioner is still an issue that I have finally found the upgrade/fix for. Also I have had this supercharger for quite some time did one install attempt and backed out because it was still my DD, now that I have my stroke this has become my trail rig only. The install is not complete, the inline fuel pump still has to be installed (the metal ford quick fuel connects had to be bought off the internet so they are en route), the fuel pressure gauge sits to high to be installed so I had to connect autometer and get a 90degree elbow off the fuel rail valve, the new long tube headers need installed with the wideband O2 sensor, the Hobbs switch and relay for the fuel system still to install, the excursion overhead console with the removed AC controls-gauges installed in it-needs to be installed (another writeup to be done). Then all the finishing touches that will be done with the AFR 185 heads, EGR spacer delete, and larger TB install. I just did this install to drive it once across the field. The next install with the new heads will allow me to finish removing all the smog crap without a CEL. Ok Ok enough check out some pictures, ask questions, and see my gallery.
All Stock
All Kenne Bell
Old lower manifold
GT40 Lightning new lower
With the huge exhaust leak, wrong air intake, a few vaccum leaks, and me being a girl with the pedal watch her idle and rev!
OOPS that was without the blower
With the Blower
Album http://s462.photobucket.com/albums/qq348/pjstevensjr/
All Stock
All Kenne Bell
Old lower manifold
With the Blower
