So I have this habit of starting on projects and giving up. I started a bearing/seal swap on my 9" a while back and never finished. At the same time I was swapping the heater hoses and snapped the fitting clean off the block. That was probably five months ago.
I finally got back to it this past weekend.
The 9" housing on one side seems a bit loose for the race, so I used some red Loctite, as recommended, and will hope it holds up. If it doesn't, I was looking at replacing the housing anyway and I'm only out an hour of my time beyond what would have been needed anyway.
Monday night I drilled/tapped the block to take a new heater hose fitting and finished it up today with new hoses and a new heater valve. The drill/tap job came out looking super clean, which is weird because I'm well known to fawk up on things like that.
Just need to pick up a new thermostat housing gasket (RTV never seems to seal for me on the housing) and I'll be done.
We have a big trail ride on the 17th called the Sweetheart Run, so I'm anxious to have it ready for the trails so this new girl I've been somewhat seeing can drive it. Hell- I haven't even driven it offroad and I'm giving her the keys.
:twak
Should be a good time.
Tuesday it goes in for some welding of spider gears on the D44, then the next project will be to get the 34x9.50s mounted up.
:twak
