i'm starting to shop for parts to do a mass air swap on my 90. all the local shops i have talked to say i need to go mass air to get my bronco to run right with all the mods that have already been done. eventually, i'll compile everything i find, and take pics along the way so i an paste it in the tech write up section.
i am still torn between what computer to run. seems like the easyest my be to run a puter outta a mass air truck with a e4od. am i better off with the truck mass air puter, or since its batch fire should i go with the al9? if its not gonna be a performace differnce between the two, seems the truck computer would be the one to have.
i was told i need to run 2 pound injectors. i found tons on ebay, and mass air meters to match them. can i use 4.6l stang injectors or mass air meters? are they the same as what is used on the 5.0l?
i am still a little unsure about what all it take to change to stock sd wire harness to work with the new puter and mass air meter. i know that has be covered before, and i know fireguy50's site has some infomation on it. when i post in the tech write up forum, i'll make sure to post pics of exactly has to be done.
i know there is things i'm forgeting to ask. i'll come back to this thread and cover them later.
anyone who has done this please feel free to post. what worked, what did not, what things cost, etc.
