1 - 20 of 24 Posts
huh
Hello.... Im at my sisters place and i was installing her old hard drive on their other computer. I did this before on my computer and had no problems. I did this on her computer and i keep getting a disk boot error or something like that.
Heres what i did.. I pulled the hard drive and switched the jumper on the back to slave drive mode then put it in her computer. connected the power and that connector thing to the back. started the computer up and got that error. i checked the jumper and it was right. i made sure everything was plugged in right and it was.. still didnt work.. any ideas?
figured id post this for the night owls.. thanks
Raf--check the existing drive that is in the PC--some HD's require a jumper when they are used in a master/slave configuration, but need no jumpers when used by themselves.
Also--is the BIOS seeing the drive? If not, you may need to go into the BIOS setup and enable "auto-detect" for the primary IDE slave drive
not much, but it's a start--ask away, maybe we can get it figured out
Jim
huh
Jim
Pulled the drive and it doesnt have a jumper on it.. Weird.
Can i get one at like Office Depot or .. Dont feel like driving out to Fry's....
Ill probably come back this weekend and give it another shot..
Another unrelated question... I had 2 extra 128mb pc133 sticks that i installed on their computer. It only had one stick in it.. Dont know what size it was.. Anyway i looked at the properties and it only shows 184mb of ram when it should have at least 256 plus what it had before.. :cry
Charlie don't surf..
'92 Ford Bronco XLT
I know that so PC's are only able to recognize up to a certain amount of ram, unless you change something in the way they're configured in the BIOS, and even then its no guarantee. Depending on how old your pc is, it ma not be able to recognize it.
'92 Ford Bronco XLT
Raf, you can enter the BIOS right when you are booting up the PC generally you have to push F2 for set up. Hold it down and it will take you to a menu. On this menu, there should be a selection for RAM or recognizing RAM or something to that effect. Its varies by computers, but once in there it is pretty self explanatory.
huh
downloaded a BIOS agent checker thing and ran it.. it lists that the max memory is 384 and the installed memory is 192. I clicked on the more info button and it shows 3 slots and each slot says that it has a 64mb stick.
edit.. thanks for that info.. ill restart and see if i can get it working..
'92 Ford Bronco XLT
The two extra stick of RAM you had, were they new sticks or did they come out of another PC. I have seen sticks that were bad before, that's why I'm asking.
huh
wasnt able to get to that setup menu when restarting..
i ran some RAM troubleshooter in windows and it did nothing..
the 2 sticks are brand new. I bought them for my computer but i didnt install them because i only had 2 slots.. i thought i had 4 like on my old computer.. they are kingston pc133 128mb
Info on the computer.. Its a Compaq Presario 5301 .
BTW.. I love DSL.. this computer has free netzero dialup.. wow............ i couldnt live with that..
hates EVERYTHING!
God I wish I could get DSL...too far in the country!:banghead At least one day I may be able to get cable...:shrug
What operating system are you running? If you're running XP you dont have to make any changes to anything, its pretty much plug and play.
How old's the computer? If it's very old (I know nothing about the configurations of Compaq's), the mother board may not support pc133. Not likely, but it's possible. Check to make sure that you installed it securely and correctly first.
huh
Discussion Starter #14
she got the computer in 1999. There was a company giving them out for free but you had to use it like 5 hours a week and the computer had ads covering up alot of the screen.. After about a month i guess some courts said it was illegal or something. They sent out letters explaining how to disable the program.
You gotta put the biggest stick of ram to the front (towards the cpu) and the smaller ones towards the back.
Is it a PC that has the video integrated on the motherboard? Some machines that have integrated video use some of your system RAM as video RAM. That might be why it's reporting less RAM than you actually have. There is usually a setting in the BIOS where you can delegate how much RAM will go toward the video. Just a thought.
huh
Discussion Starter #17
yup. i read that on the paper that came with the ram. tried it both ways.. no change.
huh
Discussion Starter #18
you got me.. i know how to use computers, dont know much about whats inside.
Try this... take out the old ram and see what happens, but don't forget to move the other two over. If it boots at all check how much ram 98 is reporting. If it's screwy, I'd say the board won't support the pc133. I don't suppose your mom kept or got any documentation for the mother board with the computer, did she? If she did, it should say what it supports.
huh
Discussion Starter #20
my mom??
it ran with just the new sticks. i tried a couple of combos.. each time it listed as 64mb per slot.
1 - 20 of 24 Posts
