Hello all,
I have an 86 FSB Eddie Bauer, 302, AOD.
I am having a center console fabricated to run from where the stock center console sits, up around the 4wd shifter is to the bottom of the dash.
My question is,
does anyone know of a shifter that is available for the AOD that i can mount on the console?
I have searched B&M, Hurst and a few others, there are some nice shiftes out there, but they only list the C4, C6 nothing for the AOD...
I really want to eliminate the stock column shifter, and as the console will be the control center for the lights, guages, radio, etc. I want to put the shifter there, I do not want to go and put the shifter on the floor, as I want it up, easily accesible and comfortable to reach and use.
thank you in advance for you help.
Chem
Practicing Infidel
If'n yer lookin' to do some manual shifting
remember the convoluted, f#@&ed up way we're supposed to "get back into 2nd gear with these AODs and consider getting a reworked valve body from these guys;
http://www.lentechautomatics.com/
It allows full automatic functions but firms up everything and permits D-2-1 manually. Doing it the Ford way has F#@%ed many an AOD.
read up on them here;
http://mustang50magazine.com/techarticles/84198/
Sixlitre
Thank you steve and sixlitre,
again with the info...
it is really appreciated.
Chem
You can use most of B&M's shifters with the AOD,
use the AOD installation kit, B&M#40496.
