1 - 11 of 11 Posts
how's this for an embarassing first post
just finished swapping in a 5.8, turned it over a few times by hand after priming...but it wouldn't crank over with the starter....so i pulled it out again....drained coolant and no problem...thani drain engine oil and white crud and water came out...as well as motor oil...i have yet to pull the heads off to further inspect
any clues where it could be mixing? not sure how i could've blown a head gasket (which is what my friends are telling me) if the enfine never turned over
thanks
CheeseBurger Milkshake!!
It could be coming from the intake manifold gasket, an improper seal is allowing the coolant to fall into the lifter valley.
Were the heads magnafluxed? One of the heads could be cracked.
But what does mine say?
I'm with yak on this one, cause it has happened to me. When the motor heats up, the soft metal in the intake settles, and the bolts need to be re-tightened. A good way to tell if it's the head gasket or the intake is to do a compression check.
this is what i was thinking too but the engine never heated up cause it never ran....looks like i plenty to check and re-torque
hates EVERYTHING!
stangmata50l said:
You could have installed the head gasket improperly. :shrug
It's got to be a gasket somewhere at least.
:stupid Should be an easy fix at least..ya just gotta find it...:shrug
Were all the passages closed? Not all engines have both the front and back passages open. Depends on years and models.
sorry...not sure what you mean by front and back passages
please elaborate
The heads may or may not have water passages on both the front and rear of the heads, Just because they have both don't allways mean that both the front and back should be open for water to flow. the gaskets may have one of the passages block for that year or model of motor. I'm not trying to say that is or isn't your problem. just my $ .02
Discussion Starter #11
OOOOOOOOOO
thanks for the explanation. is there a site or some other reference i can turn to to find this info just by using something like the casting number of the block? i have no idea what car it came out of.
1 - 11 of 11 Posts
