1 - 20 of 22 Posts
Hey - sorry to post in emergency if some of you deem it "non-emerg" but my Bronco is at the mechanics and before I authorize anything I want to make sure I'm not getting shafted.
My car has basically been leaking coolant for a looong time. My heater has been out for a year and my temp guage is always off. Eh, what the heck I finally took the truck in.
Guy says "coolant is leaking from two places: water pump and thermostat housing. will be $350."
Is this legit? Does it sound legit? :twak
Thanks - it blows because I'm getting shafted or it blows just because it sucks to lose $350?
Seriously if you guys have an answer then let me know because I at the least will not return to this shop in the future.
Clarko said:
It's definately possible. Price blows though
water pump are about $30 therm state and gasket $8 and 15 min to install thermstae and new gasket and 2-4 house waterpump so the cost of $40 you save $310 thats the issue. i just replaced the whole motor for a friend for a Pizza....boy am i cheap....lol
Bronkin' 'Round!
88 351/AOD/4” ProComp 94 351/E4OD/4” Superlift
It just seems really high to me. He'll be replacing two maybe three gaskets at the most and replacing your coolant.
There are two bolts that hold the t-stat housing on.
There are about 10 that hold the water pump on but you have to remove the serpentine brackets first. It would only take me about two hours to do it but I'm pretty handy.
Hell, you could evev get a bitchin Edelbrock hi-flow water pump like me and end up saving money over him still.
Water pump and gasket = about $50, or water pump gasket only = $2
Thermostat gasket = $2
The rest is labour.
The price is reasonable if you like taking your vehicle to a shop. It is not reasonable it you prefer to do it yourself.
Discussion Starter · #9 ·
Damn me - well, unfortunately I have no mechanic skills. Would be nice though - and I have no friends who enjoy the works, so maybe I am destined to paying shop prices forever.
How screwed would I be if I actually tried to do the work myself? Ok I guess now i'll go look for a good price on tires.
Thanks everyone.
Bronkin' 'Round!
Go into the west coast chapter forum and see if there's anyone near you. I'm down by LA so I'm too far south to help ya but I know there are some guys up your way.
green ones make me horny
Thanks everyone.
i didnt either when i did mine. that was the first thing i ever did to the bronco and an engine period. and in a year i have replaced the motor.
i dont think you will be screwed at all. if you run into hiccups search on here. if you cant find it pm me and i will tell you i have done it for a couple people on here.
Back in TEXAS
Buy a Haynes or a Chiltons, search on here, take your time, and you won't be screwed. Water pump is a pretty straightforward swap and the thermostat/housing is downright simple.
crank trigger
i agree with the other guys here, you can do this job...maybe. do you have tools? do you have a spot to do your repair? can you capture the coolant when it comes out? do you want to do it? you are mostly paying the shop for labor.
The Anti Yam!
You need to figure out what is leaking.
1. Is the water pump leaking from the weap-hole (small hole in pump) or is the gasket leaking?
2. Is the water outlet leaking from the gasket or is there a crack in it.
3. Neither will affect the heater unleas you have let the coolant level in the radiator drop really, really low.
Once you know what is wrong a Hayns manual will have step by step instructions on how to replace the parts and gaskets.
"Clever User Title Here"
Buy a Haynes and go step by step.
Gotta learn to wrench sometime. It will save you thousands of dollars over a lifetime (and make you feel more manly) if you can do alot yerself.
You shouldn't get into any trouble with a water pump/thermostat swap. Do the T-stat first, and if that's too scary, take it in.
Good luck!:thumbup
thed tstat housing would be easier without the damn water pump in the way.
i almost made a wrench just for that freakin thing. i got big hands too and it is a pain in the ass.
The Anti Yam!
Wouldn't the backside of the timing cover still be in the way?
1 - 20 of 22 Posts
