Yo Pastor Josh,
Welcome to our Big Bronco DIY Community!
Coolant Leaks:
- Damaged radiator.
- Damaged water pump.
- Loose/damaged radiator hoses.
- Loose/damaged heater water hoses.
- Damaged heater core.
- Damaged engine gaskets.
- Damaged radiator coolant recovery reservoir.
- Internal engine coolant leak.
The most common places where coolant may be leaking at engine rear are:
Hose Cracks, pinholes or splits in a radiator hose or heater hose will leak coolant. A hose leak will usually send a stream of hot coolant spraying out of the hose. A corroded hose connection or a loose or damaged hose clamp may also allow coolant to leak from the end of a hose. Sometimes the leak may only occur once the hose gets hot and the pinhole or crack opens up.
"Freeze plugs leak due to rust. They are located:
Three large per side.
Rear of the cam journal
Two small in the front by the cam journal.
One medium size in the top back of the lifter valley.
One threaded per side.
One threaded in the front by the dizzy hole. "
by absent member Aikidoka
See these
1989 Ford Truck Service Manuals - Google Drive
Click "Drive" in pop-up
Includes:
1989 Ford Bronco Electrical & Vacuum Troubleshooting Manual
1989 Bronco & Ford Truck Emissions Manual
1989 Ford Car/Truck Pre-Delivery Manual
1989 Light Duty Truck Volume A: Body/Chassis/Electrical Volume 1 of 2
1989 Light Duty Truck Volume A: Body/Chassis/Electrical Volume 2 of 2
1989 Light Duty Truck Volume B: Engine
Haynes Red Manual for 80-95 Bronco & F Series @
Hanes guide 80-96 bko f series.pdf found by member BroncMom!
See my mostly recovered site by member schwim @
Ford Bronco And F-150 Links - FORD BRONCO It contains boo-koo component repairs, installation & parts sources.
1989 Ford Bronco Dealer Brochure
1989 Bronco
Lubricant Specifications by Ford via Gary
For any Bronco questions, it's better to post each seperately in Noobie Bronco Tech Questions. Flame free zone. This will get more attention and you can build up your post count to get into other sections such as
Bronco and Ford Parts/Accessories (50 posts required to participate due to scammers who preyed on our members).
See How to add your 89s Signature @ Bronco Forum - Full Size Ford Bronco Forum by BigBlue 94
Forum
FAQs includes for example, Hot to Use Search. How To Save (Bookmark) Threads Or Posts, How To Upload Images To Posts and more tips!
Baba Looey's Favorite FSB Links (lots and lots of tech links) includes such as, How do I fix my back window?
Please find time to participate and Vote in our Full-Size Bronco of the Month Contest and later in the year, Full-Size of the Year Contest
@ Voting
You will get ideas by those competing.
Prizes are awarded to Winner!; a full spread in Bronco Driver Magazine is the top prize, in addition to a years subscription, once the article is submitted; also, a years worth of premium FSB membership.
Al
