So im on my way home from work and my window fogged up and when i got home i smelled antifreeze and it was smoking. So i popped open my hood and there was antifreeze all around the intake and antifreeze sprayed everywhere else. I have a 94 bronco with a 302. So how do i tell if i have a blown head gasket or an intake gasket leak. Any help would be greatly apperciated.
Just pull off your intake and look... If your intake looks good then keep gon deeper and pull your heads off... You really can't be 100% sure unless you visually inspect it.
Kitteh Commandaar!
If there was steam on the winsheild inside, more to the passenger side, then it's a possibility that the heater core blew up. Is there any antifreeze on the foor on the passenger side? Check all your hoses and check around the coolant sensor(s) IIRC there are 2 on the intake, one for the PCM and one for the guage.
KC
Did your Bronco overheat? Pressure test your cooling system with a radiator pressure tester.
