Well, after getting the 5.0L started, it's developed a coolant leak. It's coming from the rear of the engine. I don't believe it's the soft plug, as the motor is virtually new, and on inspection all the plugs looked good.
I had filled the radiator/engine with coolant and let it sit for almost a week before starting. No leaks. It just started to leak after I got the engine to operating temperature.
I'm wondering if it's the lower intake. I installed it with new FRP gaskets and RTV, torqued the bolts down in three stages. Re-checked torque every couple of days. I just haven't re-torqued them since the engine start.
There is no coolant in the oil, no white smoke... Just a couple drips down the back running off the spacer plate below the rear pan seal.
Thoughts?
Thoughts?
