Could it benefit me to buy different suspesnion parts from different companies and piece one together? Or should I just buy a kit? Also does the bronco sit level or is the back in sit higher? I would go look at mine but the engine is out of it so the front in is sitting high.
You can piece together a lift and get all of the premium stuff each company has to offer (cage arms, bilstein shocks, etc), but you are gonna pay a crap load more.... you could even do that by buying seperate pieces used on this site.....
Broncos have a slight (about .75ish) inch rake from back to front.... it all depends on life of springs, sag etc....
should i buy 7 inch leaf springs and 6 inch coil springs? That way it will pretty much level out
How would it make sense to buy higher rear springs and have it level out when the rear is higher to begin with?
Designated Tranny Killer
buy some 6" springs if you want the rear to sit high, most 6" lifts come with 4" rear springs to level it out
