Finally got my 87 bw1356 rebuilt to specs that work with my 93. I had to fab up a new arm at the case and i'm nut sure the detent is going all the way to 4lo (the case is though). My case locks into 4lo when it gets to the front of the raised neutral lug. I can't get the shifter to go all the way up to the forwardmost detent. I completly refurbished the linkage and added zirk fittings, so it's not stiff.
Where exactly is 4lo on the detent plate?
I also need to get the harness to make the dash indicator lights work. I refuse to pay what Ford wants for a foot long cable with two wires in it. I went to my local part stores to try and find a connector that could be modified to plug into the 4x4 indicator switch at the transfercase, but struck out. The junkyards around here never have any 4x4 ford trucks/broncos. Does anyone know of anything else on these trucks that uses the same connector that plugs into the 4x4 indicator switch on the transfercase?
