1 - 20 of 20 Posts
Andy351 said:
wheres it cracked? mine is cracked right where the back of the drivers seat bolts in.
mine too. i pulled up the floor, and used heavy fiberglass on it. crack was about 6 inchs long. i glassed out about 18" all the way around the crack. seems to have stopped it.
Mine is cracked right about there, I've had the back seat rolled up against it to try to keep the rocking down until I could get it fixed.
Excuse my lack of knowledge but how do you go about glassing something? Is heavy duty fiberglass a good long-term solution?
FSB warrior
throw some 20 gauge sheet metal over it and either pop rivet, sheet metal screw or weld it in.
FSB warrior
you can sandwich some sheet metal on your floor or stack some... and have a much stronger floor then stock!!
If you can hold out til you come down here, I can tell you exactly what you'd need to do, to fix it. and if I had a Mig, or a stick welder, I could even take care of it while you're here - if only. But for the time being, hold out on fixing for now
I have the same prob. cept mine is the back seat. Have big holes on both sides where the brackets are. :shocked NOT GOOD HUH. I would love to weld a hole sheet starting at the bottom of the hump infornt of the back seat to the back but need someone that can weld. :confused: know of anyone in central alabama that can help a bro out? :shrug :shrug would buy a round or 2 of beer :beer :beer
Diesel Gynachologist
yup thats where mine is starting to crack, its just a small one for now
Charlie don't surf..
'92 Ford Bronco XLT
Who has a pic of where this crack is?? I think mine is doing it also but havn't had the time or the inclination to pull the carpet up.
Mine had the rubber matt. Wasnt hard to take out. Just pulled it apart :toothless . Have not taken the front part out yet. Hate to see how many holes I have under my seat and the pass seat. One of these days I am going to pull all the seats out and patch up all the holes and get a Rino Liner from starting under the dash to the tip if the tail gate.:thumbup Thank that will be sweet. :toothless
1 - 20 of 20 Posts
