1 - 3 of 3 Posts
so its either i sell my bronco which i already put it up for sale but no offers or i replace a bad ring on a piston that is causing the motor to burn more oil then gas at the moment. if im going to replace the ring i will just replace all the pistons so evrything in the motor is new xcpt for the block and crankshaft. if i replace the pistons do i need to get the crank shaft rebalanced ?
I scrape on both sides
not unless you damage it putting the rings in
1 - 3 of 3 Posts
