1 - 20 of 1108 Posts
· Ford Hoarder
78 & 92
EDIT: There is a huge gap in time between this post and the next. I lost several photos and will likely not put them back. But that is ok, its like a TV show this way, where all the sudden its done ( well they are never done but further )
The truck went from being a cheap $1200 project to having a ton more in it then that (dont they all). Been working on it solidly since 2012 now. Hopefully you can bear with me on the hug gap in the dates on this thread.
Warning This build thread may also contain pics of other random Ford stuff as well as progress being made on a 1992 Bronco.
· Ford Hoarder
78 & 92
Discussion Starter · #2 · (Edited)
Truck took many changes over time. Somewhere between the post above and below it looked like this, it still does but the suspension is now extremely different.
· Ford Hoarder
78 & 92
Discussion Starter · #3 · (Edited)
Last time at the dunes
· Ford Hoarder
78 & 92
Discussion Starter · #4 · (Edited)
@jermil01, They are just ProComp Street locks with a little John Deere Yellow Detail work done on them. They do look like real ones though, kind of, they do in these pictures at least.
Just for comparison the rear wheels that my paddles are on are real beadlock wheels, the are MRW's but the raceline steelies look just like em (MRW is not longer in business)
EDIT, Really need to get that set shaved down a bit and get back on the Sand with this truck
· Ford Hoarder
78 & 92
Discussion Starter · #5 · (Edited)
For the first diversion, I also have a 2017 Mustang GT with a few goodies on it. Such as a Roush TVS 2.3L blower and some needed parts to cope with the extra power.
Took trip up to Michigan for The Lane Automotive Car Show. Was a good time, good free show.
Just for size wise I was car #617 and I registered a week or two ahead of time
Reactions: robothegreat
· Ford Hoarder
78 & 92
The "Street" truck is back in the garage for a trans swap
Got the drive shafts, shifter, and transfer case out last night. Fluids came out of the modulator, and it was kinda brown instead of red. Not good situation for having less then 100 miles on that fluid....
· Ford Hoarder
78 & 92
Out with the old
Also going to use this adapter as so I can bolt up my BW1356 down the road. The other older adapter that I have does not have all the mounts it only has the front most one.
· Ford Hoarder
78 & 92
Discussion Starter · #8 · (Edited)
Adapter got all cleaned up and is bolted on the back of the new trans.
Thinking about making it so I can extend the vent on this, but maybe not worth effort as truck should never see mud/water.
In process of changing out the motor mounts now
· Ford Hoarder
78 & 92
Discussion Starter · #9 · (Edited)
Got a stuff done this weekend while not at work.
First up installed set of Solo Engine mounts. Un like the JBG ones these do not change the engine height at all, Install was easy enough since trans out.
Then prepped new Broader 2000 Stall convertor for install
***** Performance Wide Ratio C6 going in with the above convertor. Noticed the extra strap, do not trust the POS chain on the harbor freight trans jack...
Attached to engine and held up with a strap for now. I have a C6 mount from an older bronco to put in, but in the process of cleaning it up still.
Also took the 78 to the local drive in spot on Saturday, "The Suds" was a good night for it.
· Ford Hoarder
78 & 92
Discussion Starter · #11 ·
Transfer case is back in.
Adjusted both the tcase linkage and the shifter location to fit better then when they where originally installed. Also hooked up the modulator line and the trans fluid cooler lines.
Have some trans fluids on the way, looking to have this back on the road over this up coming weekend. Did not get any pics.
· Ford Hoarder
78 & 92
Discussion Starter · #12 ·
Got some goodies from Desolate Tonight for the 92
:thumbup, I really like the gusset work and the Uniballs should work awesome.
· Ford Hoarder
78 & 92
Discussion Starter · #13 ·
Finished up the c6 install on the 92 last night should be able to put fluid in it tonight and see how it acts over the weekend.
Got some Of this to put in it
Also my H58's came in for the 78
· Ford Hoarder
78 & 92
Discussion Starter · #14 ·
Have everything to swap in the H58's into the 78 now.
Going to be using this kit from ruffstuff that I have used before with good results.
https://www.ruffstuffspecialties.com/catalog/9SS3-BIG.html
I may likely move some things around on the 92 to put my old H57's in it. They are similar but not exact matches to J40s, for example the front side of the springs is shorter on the 78/79 vs the ttb era bronco packs.
Reactions: quinault
· Ford Hoarder
78 & 92
Discussion Starter · #15 · (Edited)
So the C6 in the 92 is messed up again, or was never right from the builder. Has always been slow to engage reverse and now it fails to up shift when in drive. It will do it manually.
I am aware of checking the vacuum signal to the modulator. I think this one has a messed up valve body. So going to try and clean up the one from the other trans and put it in this one, its a Broader Performance one which I am sure is not really hurt just may have junk in it from the trans which came apart.
EDIT: To clearlify the valve body form my other trans is a Broader piece that I am really happy with, this new trans is not from them (though likely it should of been)
· Ford Hoarder
78 & 92
Discussion Starter · #16 · (Edited)
I was only using the info on Their website. I would never buy a TCI trans, not a Ford anyways too many bad things I have heard about them. I guess depends on what your looking for.
Transmission Line Pressure - TCI® Auto
***** Performance is who this particular C6 came from that I am having issues with
· Ford Hoarder
78 & 92
Discussion Starter · #17 · (Edited)
Well Animal Performance gets a fail from me.
They do have a 1 year warranty on their stuff however don't really seem to interested in helping you out after the fact. Looks like I am on my own to fix this. So the warranty is not worth anything. Will update if they make it right... For a little more info I order this on Black Friday of 2017, I did not receive it until April 21st 2018, so that is not helping them any for me.
I now have a new valve body from Broader coming as I am fairly confident that the boost valve is sticking in the animal one. Worst case I'll have an extra for a 79 f-250 that I have that will eventually get the 460 out of the 78 Bronco put in it. Like norm mentioned governor is next on my list.
Still gathering parts for the 78, I got a Afco reamer the other day to install the trac bar stud. Its nice.
· Ford Hoarder
78 & 92
Discussion Starter · #18 · (Edited)
Yeah I likely should have tried to use a shop closer, but not what happened. Just have to move forward. I do believe all the hard parts are there that I was supposed to get, and it does work in 1st and 2nd. Just has an issue somewhere else.
I did not think it would be but the modulator is not the issue, swapped it for another extra I had laying around last night (known good). I think the transfer case is coming off tonight so I can check out the governor. Not sure if tail housing adapter will have to come off to replace it or not.
Thanks for the words of wisdom if you will on this Norm. This one is just the Revenger series but its also only behind an around 400hp SBF, a good stock one should be able to take that, with a good valve body. Its another reason I am surprised to be having these issues. C6 is not known as a complicated trans either.
Somewhat related, I finished up the install of a new trans cooler last night.
9"x11"x2" (thick) core about double what I had on there previously.
Just to add some more info for anyone else looking, Animal Performance left at least 1 bolt lose on the valve body, and also did not use the correct length bolt on the servo either as it was not tight against the servo cover. The kickdown linkage I feel was also installed incorrect and as such broke when I went to move the gear selector for the first time. I could have bumped this during install, but I have never had one get in a bind from that. Usually they just end up not hitting the kickdown pin on the inside of trans. I feel that maybe this is broken/bent now internally and keeping the trans in a "floored" state. Though when I had pan off I was able to cycle it what I thought was completely.
· Ford Hoarder
78 & 92
Discussion Starter · #19 · (Edited)
Fun with C6 stuff
The shop needed a vacuum reading from the line feeding the modulator. This was less then I thought it might be, but still acceptable
If you didn't know a C6 has a line pressure port on the front drive side in front of the band adjuster. They needed this reading too
I replaced the modulator with a new black stripe one adjusted a couple turns in from fully loosened. I now have it shifting in drive. Still has near stock style shift firmness and also is slow to apply reverse. I think all of these issues are in the valve body, either leaky or sticking valves. I verified the governor works by shifting to 1st way before I should have (again good suggestion on this though Norm) It responded by not shifting until road speed was down, just like it is suppose to. So I am happy to not have to pull tcase again.
With the trans working finally took it for a drive
Really like the seat placement with the corbeau brackets, they put them a little lower which works perfect for me, easy enough to raise them a bit too if you need to
also cleaned it up when I got home.
Edit: with these issues resolved should be back on the 78 this weekend to swap the leaf springs.
Reactions: quinault
· Ford Hoarder
78 & 92
Discussion Starter · #20 · (Edited)
I agree good shop, His manual valve body you can ditch the governor and the modulator valve too. Like you said true manual.
Since waiting on my valve body had time to mess with the 78.
H57 vs H58 Deaver Springs
h57's
H58's, I am not sure why it looks like it is so tall in the rear in this pic, it is just like below.
Little better picture
From my measurements I ended up about 2" to 2 1/2" higher in the rear then I was. I put the stock block back in as so I could move it around yard. From before that was about 1/2" of lift with the wedge. With the wedge out I should end up with 1/2" rake with all my gear in the truck, 1" in normal street things in it. They should settle a bit after some use so I think I am about perfect now, turned out exactly how I wanted :thumbup
