41 - 60 of 339 Posts
Ford Hoarder
78 & 92
Discussion Starter #41 (Edited)
The shock mounts are the coil buckets are not, though could be. One of the reason why I did not weld that stuff straight to the frame. You are likely thinking of the BroncoAir Coil over mounts which I have, that I have not yet done anything with.
I agree on trac bar mount, assuming you also do a flip with the drag link to top of knuckle. One of the reasons I did not move it was to keep them in line to minimize bump steer at speeds I hope to be running.
I also think you could go with coil bucket on the truss too, But seems like a lot of work for not just going to coil overs. I would only truss the bottom if I was gonna do this one again, much more work then that I think is just a waste for still be left with a Dana 44. I Will use this one on something since I have it, but if the Sleeved and trussed housing in the 78 right now breaks I am going straight to newer radius arm Super Duty stuff. This was also my though when I did the brakes, as the hydroboost set I now run will support the bigger brakes on said axles.
All in what you want though too, everyone has their own wants/needs/style/use. :thumbup
Ford Hoarder
78 & 92
Discussion Starter #42
See, I think looks much better, just black horn button.
The reason why I went to effort of changing out the glass.
35% Tint Brow, Door Glass, and Rear Glass
Going to polish up the 18's and put those back on also. I am pleased with the Grabber AT's though too. I still have not found a 3 way switch I like to T in the transmission temp sensors. Gonna keep looking. May go to the NSRA show in Louisville, I am sure I could find something there.
Been driving it more, I in no way build this to get fuel economy however I checked it for a laugh and I am getting 12mpg, not too horrible and approaching good enough to daily it, at least in the non Salt months.
Ford Hoarder
78 & 92
Discussion Starter #43 (Edited)
I don't know if I care enough to do that, Id honestly be happy to just drive it enough to say that would actually matter. Thus far 1200 miles in 4 years is not. Like I said I checked it for a laugh. I do know of the gauge which you are talking about though. I have a handheld one I could do that with, just Velcro it to floor or something for temp. Thanks for suggestion though
I like the tint, turned out good. Guy that did it said he hasn't done Bronco in over 10 years.
I also re-centered the steering wheel, again :doh0715: I think its ok this time
Ford Hoarder
78 & 92
Discussion Starter #44
Participant Stickers from 4wheel Drive Jamboree's. I do not think they are in the way, but they have been there a long time too, I may just be used to them.
https://www.4wheeljamboree.com/
The other side has just as many Michigan State Park stickers.
Ford Hoarder
78 & 92
Discussion Starter #45 (Edited)
Got some more goodies from Desolate today. They cut me out a new front skid out of some aluminum. The air holes where supposed to be on bottom to keep stuff out of my trans cooler.
I also got their tie rod set and drop pitman arm. It was raining so I started painting up the parts for the suspension. Their tierod set is on the right side of this pic
Painted so far: Threat under bed rear shock mount, Threat Extended Rear Shackles, Threat Heim Mounts for radius arms at frame side, AutoFab center pivot boxes, Threat Coil Over Support Cross bar (over the engine), Desolate rear axle shock mount brackets.
Ford Hoarder
78 & 92
Discussion Starter #46
Ford Hoarder
78 & 92
Discussion Starter #47
Finishing some odds n ends.
Pulley spacer my Dad made for me for lower crank pulley on the '92. I did just have washers on it (not the best situation)
Got some more parts painted up, Radius arms and Coil over buckets.
All that I have left is the TTB arms themselves.
Have yet to really get back on the 78
Ford Hoarder
78 & 92
Discussion Starter #49
little over 300 miles on the C6 I was having issues with earlier in this thread. The broader valve body completely fixed it.
I recommend to anyone to do the E4OD 1st and 2nd gear set.. I am surprised at the difference this 1 change has made in the way the truck drives.
Back on the 78 this weekend, the 92 is basically done. May have it at the dunes before the end of this year.
Ford Hoarder
78 & 92
Discussion Starter #50 (Edited)
3 way switch for the trans temps works great, (its the one closest to radio) I now can look at both cooler out and trans out while going down the road.
Right now I am running around 150-170 F trans out most of the time and less then 100 at the coolers exit (it doesn't read on gauge). I have verified it is working though by artificially raising its temp.
Also got the last 2 parts for the 92's suspension painted up
Did start on the 78 but did not get any pics.
Ford Hoarder
78 & 92
Discussion Starter #51
Moser machined these to fit my disc rotors like so. I like this better then just locating on the studs, though never had an issue with them like that either.
The yukons have held up very well, considering full spool and 35, driven on the street regularly.
Comparison between 31 spline Yukons and the 35 Spline Moser's
Ford Hoarder
78 & 92
Discussion Starter #52
I didn't go back through the thread, is that a exploder disc? How was it before, just a flat end on the axle? Do they have a recommendation on max tire size for that axle?
The flange which locates the rotor in the middle, is much smaller on the stock replacement shafts. So the center OD was increased (or not machined as far in this case). Its not an explorer rotor, I would have to go back and find the part number, I do not recall what I used.
Not sure on max tire size, I did not ask as it is all kind of relative to every thing else on the truck (power, weight, expected abuse, etc). However I have seen 40"+ on 35 spline shafts in a 9" with no issues, with a good center section, full spool, and braced housing.
I am sure I will be just fine with my 35s, but I really got them to have some extra insurance when I hang the 21.50 wide paddles on the back. Also Since I got the 3rd member and bearings at the same time, it was the same money to go 35 as it was 33 or 31 spline.
Ford Hoarder
78 & 92
Discussion Starter #53
Did some part swapping tonight.
Here you can get a good idea of the differences between the stock and Moser piece
Need to paint it but I like to do these in place as I think easier. I might try to clear it instead as I like the raw look
Shafts and brakes all back in, went together just like stock, was happy I spent extra time on my measurements.
Will finish up with some fresh gear oil and putting the pinion guard and drive shaft back in tomorrow.
Ford Hoarder
78 & 92
Discussion Starter #54
Agree especially in that picture for whatever reason.
I was surprised how good of shape the old 3rd member was. Backlash still checked the same, pattern still looks good. Some wear on the teeth but not horrible.
Looking at doing semi door/seat bars in the 78 next. Some thing along this lines, with ease of entry being a priority over an actually shoulder or door bar.
Will also be adding in some braces for the sides in the back, another dash bar, and likely a few other things too.
Ford Hoarder
78 & 92
Discussion Starter #55 (Edited)
All good points, Hillbilly Heaven
In the 78 there is a rocker bar, I have the seats mounted to this as well (would look like a # from above) So the added "seat" bar will be attached in that manner, from the rocker bar up to somewhere on the main hoop behind seats. I agree on going further up for the shoulder, but ease of entry maybe different on that car the picture is from. I also want to run brace from where ever the shoulder bar is to the a lower point on the rear bar. This will support the main hoop better and also the seat bar. I do not currently have enough front to back support, at least not in my opinion. I will try to get pictures from sides and maybe some paint doodles too, of what I am thinking.
Though this is close, I stole this from the go-fast website. If the red bars went up higher, then had another support from that to the Diagnal brace, with a gusset between them.
Another reason I want to do a lower dash or "knee" bar is it will give me a good spot to build a new center console from eventually, once I get a few more things sorted out. I also thought be good spot for phone houlster and maybe some other stuff, like a Sat. Radio player thingy.
Will likely make more sense with newer pictures of the current setup. What I have is close, just not done yet to what I think I will be doing with the truck once the new engine goes in. These things are why that engine is not in it yet too.
Ford Hoarder
78 & 92
Discussion Starter #56
I know this is not a bronco but,
I was looking at doing this in the Newer bronco. I think its about as good as you can get and still get to the back, from the front.
Ford Hoarder
78 & 92
Discussion Starter #57 (Edited)
I agree on the wrap around style. Though the main reason was I like the adjustment not having them on tabs allows. Especially not know what seats I my run eventually.
Turns out getting picture of current setup is harder then I thought.
The side seat bar I want to not be further then the front seat mount bar. At least not much further. Dash bar will likely run under neat column, under the dash. more room there then I was thinking.
Finished up painting and filled with lube last night, quick spin and no issues. Might not believe me but appears that the old set of axles were twisting, compared to these on corners on pavement. These you cannot hear the tires load and unload like the 31 spline axles did a little. Likely I am only one that would notice this, on this truck.
Ford Hoarder
78 & 92
Discussion Starter #58 (Edited)
Agree on knee bar, Going to tie the bottom dash lip into it I think. Keep the whole dash from moving around, not that 78/79's have that issue. I don't actually think it will be super noticeable or in the way once done. From what I quickly looked at will not be too bad on this truck to do the knee bar, the column is more or less all the way into the dash there, so will not take much if any working around it.
Like I mentioned end goal is to also be able to make a nice transition to a center console, with cable twin stick shifter, my winters shifter, and other things I have not decided on yet.
I am likely to go buy some PVC and play with it some to see where I want things. Lot cheaper and quicker to mess with to get the basic shape down.
Ford Hoarder
78 & 92
Discussion Starter #60
Figured some stuff out tonight.
Where lower dash bar, or knee bar is gonna go
Its gonna have some interlocking tube clamps as so I can take it out. The whole cage is a bolt in so not taking the easy way out there.
Seat bar will either be straight simple tube like so
Or like this on here
Then Going to connect all these bars in the back together with one about even with the bed rail. You can see the rear most tubes which go out and grab the bed sides, imagine this one going all the way to main hoop. :thumbup
Also got the satellite radio hooked up in the garage so that is nice to have. Kind of funny as do not even have that in the house.
