So I figured I'd try my hand at a tech write up, let me know what you all think,
Also, I know this doesn't pertain to every bronco but there are a few guys on here besides me with Cummins powered fsb's, or Dodge trucks so its a little relevant haha.
So first were gonna start by removing the motor. I decided to do this since it was my first time doing a Hg and the Cummins is shoved pretty far back under the cowl of my bronco.
You can see here where it was leaking if you were wondering.
If you are pulling the motor out, like I did you need to set you engine up so you can work on it. I used a 6x6 and a 4x4 supported by multiple jack stands to keep it level and relatively stable while you're working on it.
Starting teardown- Start by removing the 4 10mm bolts that hold on the crossover pipe aka the intake horn on the intercooled motors.
Disconnect the throttle linkage ( it just pops right off), on a side note don't be to rough with the linkage, the plastic ends are brittle, and will snap right off.
Next, remove the 10mm bolt that attaches the dip stick to the side plate.
Follow this by removing the last 10mm bolt (below the injection pump) and removing the side cover
Here's the side cover so you know what your looking at.
Next thing your going to remove is the crossover pipe if your motor is non ic, skip this step.
Now on to removing the turbo, start by disconnecting the 5/8" oil feed line, and the oil drain line. Then remove the 4 15mm nuts holding the turbo to the manifold. (Since my manifold is flipped one if the bolts is really hard to access you will need to grind down the wrench to get it to fit)
Now, remove the manifold, there are 12, 13mm (1/2") bolts holding it on. If they haven't been removed recently you are gong to want to be very careful and use some heat, if one of these breaks off you’re gonna have a hell of a time getting it out.
You can see here that I bagged and labeled everything I removed, it just makes it that much easier to put back together.
Remove all the valve covers next. Bolt size is 15mm.
Now you can start disconnecting all the injectors (11/16) on the line nuts. I believe (3/8) on the return line banjo bolts, be sure not to lose the tiny sealing washers n the return line when you disconnect them. I labeled all the injector lines as I was disconnecting them. The return line is the small one towards the bottom of the picture
Next, I disconnected the injection lines from the injection pump (11/16")
After the supply and return lines from the injectors are removed you can remove the injector nuts (7/8) and pull the injectors out. Some of the injectors will come out by hand others are kind of stuck and you will have to use some vise grips to remove.
Adjust all the rockers so that every spring has no pressure on it so you can remove the rocker assemblies.
After loosening the rockers, start loosening all the head bolts. Once they're all loose remove the rocker assemblies and label which goes to which cylinder.
After removing all the rocker assemblies mark a piece of cardboard to keep track of the pushrods.
Now before you pull the head off you need to make sure the fuel lines connected to the head are disconnected, there are 2 5/8 banjo bolts that connect the fuel line to the cast filter housing in the head, remove those.
http://www.supermotors.net/getfile/890557/fullsize/img_0894.jpg[/img
Also going to have to disconnect the water neck and remove the thermostat (it’s a good idea to replace while the motor is this torn down anyways) There are 3 10mm bolts holding the water neck on, loosen them all and you can swing it out of the way along with the alternator
[img]http://www.supermotors.net/getfile/890559/fullsize/img_0896.jpg
